Informations about SlimLine I2C expansion bus
Home › Forum › Controllori SlimLine e Netsyst (LogicLab) › Informations about SlimLine I2C expansion bus
  • #35488
    I plan to use your SlimLine I/O modules with I2C interface,  is it possible to share the protocol for that purpose ?
    I can not use the RS232 because several modules wouldnt be on the same line. do the modules support RS485 ?
    #37997
    The SlimLine I2C expansion bus is managed with complex I2C commands, each command is composed by a write command followed by a read command. Are managed 256 commands each composed with multiple bytes, to each command sent by the CPU, the extension module creates the response frame that is read by the CPU.
    The CPU module has to manage multitasking accesses, so all the I2C slave management is made with a FPGA logic to ensure the communication interoperability between the different tasks. All of this requires a management workload from the CPU and to avoid problems in the commands timing, we don’t publish any reference on how to manage the bus by a third party. So our I/O modules can be managed only by our CPU modules.
    #37998
    But if your requirement is to create a RS485 network with many remote I/O modules attached, you can use our Compact CPU module. It has 6 digital inputs, 4 relais outputs, 2 analog inputs, there is a version that has the RS485 port and supports the Modbus protocol. If you need more than the embedded I/Os, you can connect to it other I/O extension modules.
    In this topic you will find a description of a project with a master CPU module that manages many slave compact modules connected on RS485. The main feature of this example is that it’s possible to program the slave modules by the RS485 network directly thru an ethernet connection to the master CPU. The topic is in italian but you can download the source program and study it.
