Unable to connect with LogicLab
Home Forum SlimLine (Raspberry) Programmazione con LogicLab Unable to connect with LogicLab
  • #66744
    Gregory
    I am trying to setup a SlimLine Raspberry Pi to work with LogicLab and I am unable to connect to the PLC to install permanent runtime license.
    Please see screenshot for steps I have tried.
    #66763
    The Device Discover function founds devices also if they are in an outside network masks. But as I can see by the ping this is not your case.
    So if the LogicLab doesn’t connect to the devices could be determinated by the the LogicLab runtime that is not currently running on the Raspberry module. As you can see in this article the LogicLab run time is preinstalled but it’s not running. So before connect the program you have to run it.
    A strangeness is in the module with IP 192.168.50.3, raspberry Unregistered, this is securely not the situation you found on a new module. Probably you have deleted some files or updated the SDCard image (See article).
